Prevent from power/battery savers
To work properly MyCarTracks runs in the background. All major devices come with their own battery-saving features which are good for your battery life but what they actually do is block apps running in the background. This causes that MyCarTrack is also blocked which results in not recording all your journeys and then you think our app doesn’t work properly. The same applies also to any battery saver apps (Advanced task killer, Battery doctor, Juice defender, …) you can install on your device.
Make sure that MyCarTracks is not blocked by any battery saver app or feature. Here are some manuals that you can follow:
Brand-specific instructions
If you find any other way that helped you please send us your hints to support@mycartracks.com.
Quick brand-specific instructions
Huawei – Only Pre-EMUI 5.0 / Android 7 – Go to Settings > “Protected apps”, check MyCarTracks.
Sony – Tap on the battery icon. Go to Power Management > STAMINA mode > Apps active in standby > Add MyCarTracks.
Asus – Check MyCarTracks app in the Auto-start Manager.
Xiaomi – Security (App) > Permissions > Autostart – Enable MyCarTracks app
*New Xiaomi – Settings > Developer Options. Disable “memory optimization”. To enabled Developer Options go to Settings > About. Tap on MIUI 8 times.
Oppo – Go to Settings > “Security settings” > “Data saving” and enable MyCarTracks app.
Samsung – Disable battery usage optimizations
